Activity › Forums › Sony Cameras › ZOOM controls
ZOOM controls
Posted by Phillip Ebed on January 31, 2008 at 9:54 pmAs i said I used all three. but to be fair I used the VZ and BB.
ones with the hvx 200 and not with the EX1.and I used the Libec only with the EX1.
I would love to hear if the VZ and BB connect to the front of the lens like the Libec instead of the lan like on the HVX 200.
Micheal how does your new one connect and do you like it?
Phill.Phillip Ebed replied 18 years, 7 months ago 5 Members · 6 Replies -
Michael Palmer
February 2, 2008 at 5:20 pmI’m still waiting for it, and it will connect to the port on the lens. VZ only produced 100 of these and I didn’t pre-order. I will get it from the next run.
Good Luck
Michael Palmer -
Michael Stevens
February 3, 2008 at 7:38 am -
Steve Wargo
February 4, 2008 at 1:39 amI can verify that the std Fuji connector does not fit into the hole
Steve Wargo
Tempe, Arizona
It’s a dry heat!Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1. -
Ron Shook
February 4, 2008 at 3:27 amSteve and all,
After following links here to other forums I tracked down this Libec zoom controller. It’s their standard Fuji/Canon Pro controller with an adapter at the end. The picture doesn’t show the adapter:
As I researched, even though at $250 this is the least expensive of the bunch, a couple of folks who’e tried it comparatively to VZ and another brand thought it worked the best. I’m not sure if they tried it with EX, but it seems like very much worth a try. Plus it’ll work with just about any other pro lens you have. BTW, I found it another place and they wanted $400 for it.
Ron Shook
Shoulder-High Eye Productions
CreativeCOW Forum Host for Discreet edit* -
Steve Wargo
February 4, 2008 at 8:58 amI have a Libec handle for my pro canon lenses that is a real workhorse. I bought it for $235 from a dealer in St. Louis through e-bay about 5 years ago. It works as well as the Canon I paid $1200 for, and, for $35 more, he gave me the correct part to screw it on to my Sachtler 20 head. All good on that. I’ll have to see if I can dig his contact info up somewhere.
Steve Wargo
Tempe, Arizona
2-Sony EX-1. -
Phillip Ebed
February 4, 2008 at 5:11 pmIt does work well with the EX1. and it does need that adapter.
but what a nice smooth feel to it.I only wish the toggle
was a little wider.
ABEL Cine and band pro can get them but there are not shipping until some time in Feb.
phill.PHILL.
