Activity Forums Sony Cameras Zipping a BPAV folder
  • Zipping a BPAV folder
    Posted by Mike Drew on February 19, 2010 at 12:32 am
    Hi all, has anyone had any problems zipping a BPAV folder for transfer via FTP? I will get the cards a day or 2 later but the cut has to start ASAP after the shoot in another city.
    Thanks in advance.
    Mike
    Mike Drew
    Avid AE Shake Flame
    Mike Drew replied 16 years, 6 months ago 2 Members · 2 Replies
  • Craig Seeman
    February 19, 2010 at 12:49 am
    Just to be on the safe side I’d but the BPAV in a parent folder with a unique name and zip that.
    I can see a bit of a mess happening if you unzip multiple BPAV folders all named BPAV.zip
    You’re going to need some heavy duty bandwidth speeds to move these files around.
    You might need to check both the sender and receiver speed to whatever distant server to see what speed you can expect. Your local speed may even be very fast but it’s the speed to the area you’re sending to that’s important.
    https://www.speedtest.net/index.php
  • Mike Drew
    February 19, 2010 at 2:25 am
    Thanks Craig, I’m not worried about bandwidth (dedicated fibre between studios) just file corruption.
    Any thoughts?
    Mike
    Mike Drew
    Avid AE Shake Flame
