Activity Forums Zaxwerks Zaxwerks render help
  • Zaxwerks render help
    Posted by Javier Lopez on February 9, 2007 at 3:22 pm
    Hello,
    I had created a 3D text in Zaxwerks and exported as a Quicktime Animation to composite in After Effects, but the video looks bad, does not have detail, raged edges and it flares, I had used the following settings in Zaxwerks to render:
    *Pixels: Square (1.0)
    *Resolution: 720 by 480
    *Render: Invigorator
    *AntiAliasing: 5by5+1.5
    Any advise please?
    Thanks in advance.
    Matt Rhodes replied 19 years, 6 months ago 3 Members · 3 Replies
  • Jon Okerstrom
    February 9, 2007 at 7:11 pm
    Hello.
    Did you render fields or frames? (interlaced video can look bad on your computer – worse on a monitor if the field order is wrong). Check your import settings for field order, fps, etc.
    Jon
  • Javier Lopez
    February 9, 2007 at 9:19 pm
    Hello,
    I had tried all the options, field order, full frame, pixel aspect ratio, everything, and still… no luck.
    Any possible solution?
    Thanks.
  • Matt Rhodes
    February 11, 2007 at 10:56 pm
    Hello.
    Would you mind sending me the file and giving
    me instructions on how to replicate problem?
    I’d be happy to take a look.
    Send the file(s) to: matt@zaxwerks.com
    Matt Rhodes
    Zaxwerks, Inc.
