Activity Forums Zaxwerks Zaxwerks Problem – Need Help
  • Zaxwerks Problem – Need Help
    Posted by Image Reign on July 26, 2007 at 4:48 am
    I am trying to install my 3d invigirator pro plug in to my After Affects CS3. When I put my serial number in it says “Your permanant authorization code has been accepted”. Then I get an error message saying ” Invalid Zaxwerks Preferences folder- cannot open security file. Program will be cancelled.”
    I tried changing my files from read only it doesn’t work. I don’t know if this is a Windows Vista Problem or a Zaxwerks Problem.
    Can Some one please help?
    Dcdave replied 18 years, 11 months ago 3 Members · 2 Replies
  • Matt Rhodes
    July 26, 2007 at 4:37 pm
    Hey IR.
    It sounds like a Zaxwerks problem on Vista.
    Can you email me offline (matt@zaxwerks.com) so
    that I can ask you a few questions?
    Once we figure out the issue, I’ll post a note in the forums.
    Thanks a lot.
    Matt Rhodes
    Zaxwerks, Inc.
  • Dcdave
    September 24, 2007 at 2:51 pm
    I have this same problem. I’m using Vista Ultimate X64 with AE CS3. However, when I install Invigorator Pro 4.3 on AE 6.5, which is also installed on the same machine, it works. Wonder if this is a problem with CS3 instead of Vista
