Activity Forums Zaxwerks Zaxwerks on different computer
  • Zaxwerks on different computer
    Posted by Adam Duplay on December 9, 2010 at 2:07 am
    I just opened a Zakswerks / After Effects project on a second computer, not the computer where I created this project.
    The problem is, all the Zaxwerks layers appear at a slightly incorrect size. They are only slightly incorrect, almost like their pixel aspect is incorrect, but not that uniform. I’m not sure if that is what the problem is.
    Any ideas?
    Adam Duplay
    Edward Wu replied 15 years, 9 months ago 2 Members · 1 Reply
  • Edward Wu
    December 10, 2010 at 12:44 am
    Hi Adam,
    If you have the “Toggle Pixel Aspect Ratio Correction” set differently on the other computer, this may cause the project to look different on the other computer. Also, be sure the Solid layer is set to “Make Comp Size”. If the Solid is not set as the Composition Size, the objects/perspective may not look accurate.
    If you are still having issues, try sending a screen shot or the project file to me at ed@zaxwerks.com so I can take a look at what you are running into.
    Best,
    Edward
