Activity Forums Zaxwerks Zaxwerks 3d invigorator slow!?
  • Zaxwerks 3d invigorator slow!?
    Posted by Tony Vega on April 24, 2008 at 9:48 am
    I have 3d invigorator 4.0.0 installed in ae cs3
    everytime i use invigorator it goes slow and i cant work with it ,why?
    Tony
    Mountaga Dramé replied 16 years, 12 months ago 3 Members · 3 Replies
  • Matt Rhodes
    April 27, 2008 at 5:32 pm
    Hi Tony.
    The default rendering mode for Layers in AE CS3 is Best mode. You may want to switch the Invigorator layer’s rendering mode to Draft mode.
    You may also want to consider upgrading to the current version of the Invigorator – v4.5.
    https://zaxwerks.com/download
    Let us know if this helps your situation.
    Matt Rhodes
    Zaxwerks, Inc.
  • Tony Vega
    April 28, 2008 at 8:10 am
    yes i upgraded it to 4.5 and it workd very nice!
    thank you very much
    Tony
    Sweden
  • Mountaga Dramé
    September 28, 2009 at 3:35 pm
    Hello to all
    I intall 3d invigorator 4.0.0 in after CS4 (English version) and since I have a problem with the color palette. Indeed I can not enter more than two numbers in the boxes (rgb) and it is even with proanimator.All options are in English except the color that is in French.
    I installed Windows xp French version.
