Activity › Forums › Adobe After Effects › Zaxwerks 3d flag crashes when project is saved
  • Zaxwerks 3d flag crashes when project is saved
    Posted by Paul Hanson on February 8, 2006 at 11:46 am
    Can anybody shed some light on this problem,
    I’m using zaxwerks 3d flag which works fine and saves fine, but when the project is called up and adjustments made and you try to resave after effects crashes, and you do not want to emergency save as this just crashes every time you try to open it. The error message reads thus “After effects error: crash occurred while invoking effect plug-in “3D Flag””.
    This happens on both of my macs – g5 dual 2g and g5 dualcore 2.7g, both machines also have 3d invigorator on them and are running ae 6.5 with pal comps.
    I’ve checked the archives and can not see anything on this subject.
    ta v much
    Paul
    Betty Boop2 replied 20 years, 7 months ago 2 Members · 1 Reply
  • Betty Boop2
    February 8, 2006 at 5:04 pm
    Post to the Zaxwerks forum. YOu will get a much faster answer.
    Jay Thompson
    Thompson Visual Design & Storytelling
    7 Marjean Ct.
    Kirkwood, MO 63122
