Activity Forums Adobe After Effects Expressions Z-rotation linked to two points – one is 3D and the other 2D
  • Z-rotation linked to two points – one is 3D and the other 2D
    Posted by Roland R. kahlenberg on August 1, 2011 at 5:25 am
    Hi peeps, I’m looking for an Expression to link the Z-rotation property of a layer from two points residing in two separate layers – one is 3D layer and the other is 2D.
    TIA
    RoRK
    Intensive AE & Mocha Training in Asia.
    Roland R. kahlenberg replied 15 years, 1 month ago 2 Members · 4 Replies
  • Dan Ebberts
    August 1, 2011 at 1:20 pm
    Are you talking about something like this?
    L1 = thisComp.layer("2D Layer");
    p1 = L1.toComp(L1.anchorPoint);
    L2 = thisComp.layer("3D Layer");
    p2 = L2.toComp(L2.anchorPoint);
    v = p2 - p1;
    radiansToDegrees(Math.atan2(v[1],v[0]))
    Dan
  • Roland R. kahlenberg
    August 1, 2011 at 2:04 pm
    That works well Dan BUT I’ve found another issue. Here’s the scenario –
    I have the Beam effect linking the two points mentioned. I would like to place a Text Layer along the Beam; centered will be fine but it’ll be better if I am able to move the text anywhere along the Beam.
    Right now, the Z-rotation for the text layer looks good but there are instances where the text strays away from the Beam.
    Cheers
    RoRK
  • Dan Ebberts
    August 1, 2011 at 6:48 pm
    This should position the text anchor point at the center of the beam:
    L1 = thisComp.layer(“2D Layer”);
    L2 = thisComp.layer(“3D Layer”);
    (p1 + p2)/2
    You could add a Position animator tied to sliders to adjust the x and y, if necessary.
    Dan
    August 2, 2011 at 4:40 am
    Awesome! How can I convert my 2D Beam layer (Solid) to a 3D layer (cos I’d like some 3D shadows) and keep everything sexy?
    TIA
    RoRK
