Activity Forums Adobe After Effects Z position to scale? or 3d flare
  • Z position to scale? or 3d flare
    Posted by Andy Phillips on January 5, 2011 at 1:31 am
    I’ve been following video copilot’s tutorial on smoke trails with particular and optical flares, but i have been trying to use just the built in plugins to achieve the same result. I have been pretty successful with the smoke trails themselves, but I run in to trouble with the lens flares. I tried linking the 2d flare’s scale to the null object’s z position and the x and y to the null’s x and y position. however, the z position goes from a negetive number to a positive number, and the the scale then goes in reverse. Is there a simple expression that would make the scale relative while keeping it in the same position as the null? or is there an easy, free way to create a 3d flare without using any external plugins?
    I just joined so i’m not sure if this should belong in the AE expressions section, so please tell me if it should
    Andy Phillips replied 15 years, 8 months ago 3 Members · 5 Replies
  • Andy Phillips
    January 5, 2011 at 11:46 am
    Is there a way to delete posts? i figured out a work-around
  • Alex Dinnin
    January 5, 2011 at 1:03 pm
    that’s wierd.. I was just reading about this…
    here’s what they say at Video CoPilot
    https://www.videocopilot.net/blog/2009/08/lens-flare-on-3d-lights/
    who am I to argue..
    and yep.. I reckon it should have been in the Expressions Forum
  • Andy Phillips
    January 5, 2011 at 1:56 pm
    oh thanks, I didnt see that. that should help!
  • Walter Soyka
    January 5, 2011 at 5:52 pm
    No need to delete your post if you’ve figured out a work-around — but posting your solution might help people who find this thread in a search later.
    Good luck with your project.
    Walter Soyka
  • Andy Phillips
    January 5, 2011 at 10:06 pm
    the work-around was to simply have a small particle system with a low velocity following the null, then apply a tint and glow effect. making the particle “explosive” made a pretty good bright light/lens flare
