Activity Forums Adobe After Effects z-depth pass channel combiner?
  • z-depth pass channel combiner?
    Posted by Remy Mainz on April 9, 2009 at 10:20 am
    Hi ccows!
    I have seperate passes from 3dsmax , 1 normal and 1 z-depth as tif sequences. I cannot combine them in a single file , ie RLA, because of a bug in max that wont render shadows with Mental Ray renderer if z-depth is on. SO I have to save them as completely seperate renders and therefore tifs sequences.
    How do I make them work together in AE?
    I cant see how to make the z-depth be a channel for the normal pass layer?
    thanks joe ger
    Darby Edelen replied 17 years, 5 months ago 2 Members · 1 Reply
  • Darby Edelen
    April 10, 2009 at 12:04 am
    [joe ger] “I cant see how to make the z-depth be a channel for the normal pass layer?”
    Can you explain what you mean by that?
    Darby Edelen
