Activity Forums VEGAS Pro Youtube pixelation?
  • Youtube pixelation?
    Posted by Lukas Hajk on August 14, 2015 at 3:21 pm
    Hello guys,
    After many, many hours of searching for the best youtube settings, I’ve given up and I’m trying it for the last time here on this forum as I’ve seen some good suggestions here.
    I’m a game moviemaker, but over the years I wasn’t able to find those “Clear crystal” settings for youtube as I have seen on other guys’ channels. I’ll try to be as short as possible.
    – Vegas settings
    https://ctrlv.cz/24zf
    https://ctrlv.cz/K9YX
    When I render the file, the quality is so good, basically no pixels anywhere, just as it should be. But when I upload it on youtube, the quality is just horrible and it feels like it’s my first day in Sony Vegas and I have no idea how to upload a good quality video.
    Take a look for yourself :/
    Original – https://ctrlv.cz/Q01X
    Youtube – https://ctrlv.cz/9ra3
    Is there anyone who could help me? I just have no idea what to do anymore.. losing my motivation.
    Would appreciate a lot, thanks!
    Oliver Nilsson replied 10 years, 9 months ago 6 Members · 48 Replies
  • 48 Replies
  • Danny Hays
    August 14, 2015 at 4:35 pm
    I took a screen shot of your original and used these settings and this is what a 5 sec you tube vid looks like for me.
    In the render settings, in the project tab, I set render quality to best.
    https://youtu.be/bKJEBNxTc9U
    Danny Hays
    Samples of my Work can be seen here:
    https://www.youtube.com/user/ErnestDaniels/videos
  • Lukas Hajk
    August 14, 2015 at 6:08 pm
    Hello Danny,
    thanks a lot for your input. I took a look and the only difference in our settings is that you selected CBR at 50mbps and 32bit (full range) quality colors. I’m going to try the CBR at 50mbps as well and at the same time I’ll try to select 32bit (video levels) color quality. It seems as if the colors with the full range quality are a bit too dark.
    Anyway I’ll write back when I’m done with the testing, I’m in the process of doing it.
    Once again, thanks a lot for reply!
  • Lukas Hajk
    August 14, 2015 at 6:26 pm
    Ok Danny,
    I just tried the same as you did with the screenshot. Just to be sure if it’s not something with my pc etc.
    The result is the same. Crystal clear quality… -> https://www.youtube.com/watch?v=9v0p-qG1zvc
    that means, what destroys the quality is the movement. I’ve tried smart resample (which I really hate) and no resample, it seems to be a problem when using both of them.
  • Danny Hays
    August 14, 2015 at 7:25 pm
    Did you upload a video to YouTube using the settings I used? If you did, can you post a link for me to see?
    Danny Hays
  • Lukas Hajk
    August 14, 2015 at 7:27 pm
    Yes I did. Except for the 32-bit full color, Youtube didn’t want to process the video using that option.
    So I just chose 32-bit video levels
    Here you go: https://www.youtube.com/watch?v=jEBsuvOkpW8
    I hope it’s just not me, but the quality is still terrible… you can immediately see the pixeling on the trees.
  • Danny Hays
    August 14, 2015 at 7:39 pm
    That’s weird. YouTube did it for me with those settings,,,,?? I can’t see your video unless you set it to listed or public. Private means only logging in as you lets it be viewed.
    Danny Hays
  • Lukas Hajk
    August 14, 2015 at 7:52 pm
    Gosh.. sorry 😀 I swear I set it as Unlisted, apparently not 🙂
    You should see it now.
  • Danny Hays
    August 14, 2015 at 8:49 pm
    I see what you mean. Does it look good after the Vegas render, before YouTube encodes it? That’s a pretty small clip. Anyway you can dropbox it to me, or even a one second sample so I can experiment with it? A 1 sec. clip may be small enough to email it to me. danhays2004@yahoo.com
    Danny Hays
  • Lukas Hajk
    August 14, 2015 at 9:54 pm
    It looks absolutely amazing when I watch it from the PC. But once Youtube encodes it, this is the result.
    Yes sure I can, I’m just going to sleep so I’ll get it for you tomorrow!
    Thanks once again for your replies.
    Have a nice day!
  • Norman Black
    August 15, 2015 at 12:30 am
    If what you render from Vegas looks good on playback and the Youtube result does not, then there is NOTHING you can do.
    Youtube re-encodes everything uploaded to their own spec. Their spec is very low bitrate and very often game material does not compress well enough to maintain a certain visual quality. This has nothing to do with some magic encoding setting. It is entirely dependent on exactly what is going on in the video at at every instant in time.
    Again, if your encode looks good, then how is it possible that giving Youtube something different can possible help. The loss of quality is entirely from the Youtube re-encode. If someone elses game video looks better then the the specific sequence of frames in their video just compressed better into the low Youtube bitrate than yours did.
    https://support.google.com/youtube/answer/1722171?hl=en
Page 1 of 5
