Activity Forums VEGAS Pro Youtube minidv footage looks poor and blocky
  • Youtube minidv footage looks poor and blocky
    Posted by Alex Kye on December 13, 2010 at 10:35 pm
    High, I have followed countless guides on the internet into getting MiniDV 720×576 25fps 16:9 footage to look good on youtube. the problem is they always come out looking blocky and just generally poor quality even after waiting for the video to process.
    I have tried de-interlacing and rendering out of Vegas using .wmv and .mp4 (trying both de-interlaced and interlaced) yet the video still looks nothing like other videos taken with the same camcorder (Sony DCR-HC62E).
    Have any of you Vegas experts got any tips or pointers into why my video always come out looking poor, even my cheap digital camera takes better video than my camcorder.
    Here is one of the videos with the rest on my channel have been taken with my digital camera.
    https://www.youtube.com/watch?v=ii76KEW7SiE as you can see the video is slightly blocky and very washed out.
    Any ideas?
    John Rofrano replied 15 years, 8 months ago 3 Members · 20 Replies
  • 20 Replies
  • Aleksey Tarasov
    December 14, 2010 at 4:58 am
    Try free Video4YouTube plug-in for Sony Vegas Pro
  • John Rofrano
    December 14, 2010 at 4:17 pm
    [Alex Kye] “Have any of you Vegas experts got any tips or pointers into why my video always come out looking poor, even my cheap digital camera takes better video than my camcorder.”
    Set your project properties to PAL DV Widescreen (720×576, 25.000 fps). Don’t change any settings. Make sure that your Deinterlace method is set to Blend Fields.
    For rendering you will need to make your own template. I would use the Sony AVC render type and start with the Internet 4:3 SD 25p template and change it to 16:9. To do this, set the Frame size to (Custom frame size) and set the Width to 1050 and Height to 576. Like this:
    Your video should look great on Youtube. It it is still blocky, increase the Bit rate (bps) to 4,000,000 or higher.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Alex Kye
    December 14, 2010 at 5:09 pm
    Thanks for the reply, but after trying those settings it still looks blocky and washed out
    https://www.youtube.com/watch?v=VYu2O2wRuC0
    Do you know what is usually the cause for these “blocks” appearing in video?
    @Aleksey Tarasov thanks but I am not comfortable inputting my youtube login details into something I have not heard of.
  • Aleksey Tarasov
    December 14, 2010 at 5:26 pm
    The Upload function is optional. Just disable it.
    Render function will work.
  • Alex Kye
    December 14, 2010 at 10:17 pm
    @Aleksey Tarasov I tried that but the quality was still poor and blocky.
    @John Rofrano Still no luck when trying your directions. How ever if I render using 1280×720 it looks much better when viewed in 720P on youtube, but still poor in lower resolutions and with an internet connection like mine 720P takes an age to buffer.
    https://www.youtube.com/watch?v=JaPiFXhoLBM
    , how ever there are videos taken with the same camera by other people that look fine in 360P and 480P like this one
    https://www.youtube.com/watch?v=mQG20bj6m_I&feature=related
    I am out of ideas as into why my footage comes out looking poor when there are people using less advanced means to edit their footage yet it comes out looking fine.
  • John Rofrano
    December 15, 2010 at 4:57 am
    [Alex Kye] “I am out of ideas as into why my footage comes out looking poor when there are people using less advanced means to edit their footage yet it comes out looking fine.”
    What does it look like before you upload it? What bit-rate did you use? Did you try increasing it?
    Also, since Youtube doesn’t support 576 you might want to render to NTSC 873×480 instead.
    ~jr
  • Alex Kye
    December 15, 2010 at 5:30 pm
    Before I upload it, the video files rendered out in Vegas look fine when played in VLC media player and windows media player. it is just when uploaded to YouTube they look blocky and loose lots of quality.
    I have tried many bit rates from the 3mbps you recommended all the way upto 15mbps yet they still look the same.
    I am going to test NTSC 873×480 now to see what results I get.
  • Alex Kye
    December 15, 2010 at 6:23 pm
    Edit: still no luck, same blocky effect
    https://www.youtube.com/watch?v=Jr-V5zr5PvE
  • Aleksey Tarasov
    December 16, 2010 at 5:29 am
    Could you share your original clip for testing?
  • Alex Kye
    December 16, 2010 at 10:17 am
    @Aleksey Tarasov Do you mean sharing the original .AVI clip (very large) or the rendered .MP4 clip on a file sharing site? (The rendered .MP4 clip looks fine on my computer in VLC media player).
    Thanks.
