Activity Forums Apple Final Cut Pro Legacy Young filmmaker needs help with 30P
  • Young filmmaker needs help with 30P
    Posted by Teague Fleury on August 25, 2009 at 1:32 am
    Here’s what i need help with. Keep in mind that my technical experience is limited.
    I have finished shooting a documentary and now have 60+ DV tapes of footage.
    I shot on two separate cameras, a Canon Vixia HV30 and a Canon XH-A1.
    The majority of my footage was shot in 30P (or 30F as the HV30 calls it).
    5 hours or less was shot in 60i.
    I will be editing in FCP.
    I intend to enter my film into film festivals and pursue distribution.
    Here’s what I need help with. With my current media (I can’t go back and shoot in 24P guys), how can I produce the best looking DVD to enter into festivals and give to my sales agent? I need to know the best way to capture into FCP, the best codec to use and the best way to export. I realize that transfer to 35mm will be next to impossible because of the 30P but that will be a welcome problem to deal with if the time comes. I also understand that many new digital projectors can play 30P. I am desperate for advice as I am self taught and rely on people like you to learn and grow my passion.
    What combination will give me a high quality result? I am aware that there are hundreds of ways of doing things but I am hoping that I can get some solid answers as to how I should proceed. I truly appreciate any help or feedback you can give. Thanks
    By the way, storage space is not really an issue here because I have 4TB of eSata hard drive space.
    -Teague
    NOMAPSfilms.com
    One Man. Two Wheels. No Maps.
    NOMAPS Films is currently in post production on a feature length HD documentary film about a solo motorcycle adventure from CT to Panama… and back.
    Dan Nocera replied 17 years ago 6 Members · 9 Replies
  • 9 Replies
  • Matt Doe
    August 25, 2009 at 1:56 pm
    Has the footage been captured yet?
    If not, you want to capture native to what was shot, in this case HDV. The easiest way to go is use the Easy Setups in Final Cut to match what you shot and capture over firewire.
  • Chris Poisson
    August 25, 2009 at 4:43 pm
    I disagree completely. Capture to ProRes, drives are really cheap right now and the quality will be outstanding and no conforming. Transitions and color correction will be far superior to editiong with HDV, even if you render to ProRes. Start out with a codec worth editing with.
    Have as good a day as you can.
  • Teague Fleury
    August 25, 2009 at 8:16 pm
    So it’s definitely worth the extra storage space to capture to ProRes HQ? I read in a seperate forum that by capturing hdv to prores, the footage compresses even further rather than making an exact copy by capturing to native hdv. I want to know what’s best before i spend weeks capturing all this footage. Thanks very much for your help.
    -Teague
    NOMAPSfilms.com
  • Matt Doe
    August 25, 2009 at 8:25 pm
    Chris is right, capturing to ProRes is the way to go, totally forgot about that option (even though that is what I do with all my 5D Mark II footage) with my first response.
    You will not be compressing the footage more by capturing to ProRes
  • Gary Adcock
    August 25, 2009 at 8:50 pm
    [Teague Fleury] “So it’s definitely worth the extra storage space to capture to ProRes HQ? I read in a seperate forum that by capturing hdv to prores, the footage compresses even further rather than making an exact copy by capturing to native hdv.”
    you gain nothing from going from HDV to ProResHQ.
    Plain ProRes is more than sufficient for your needs with all the benefits and 50% less hassle.
    as for converting to PR from HDV- the other poster is incorrect, as ProRes will actually keep MORE detail and Color intact since your footage is I-frame 4:2:2 @ 10bit instead of HDV’s GOP based Mpeg as 8bit 4:2:0
    funny my math tells me that while you will not gain anything- you also will not loose anything in the translation.
    Please take a look at my prores article listed below.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflow for the Digitally Inclined
    Chicago, IL
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
    ProRes-A Closer Look
    https://tinyurl.com/b3c3nx
  • Matt Devino
    August 25, 2009 at 10:20 pm
    I agree with these guys, ProRes (not HQ) is the way to go. For the 60i stuff just capture it as 60i, but work in a 30P timeline and it should look nearly identical to the 30P footage. Use the easy setups FCP provides for HDV to ProRes conversion over firewire, they will keep your footage at the original 1440×1080 aspect ratio which is a good thing as it will save drive space. You can convert to 1920×1080 square pixels when you are finished editing and ready to master.
  • Chris Poisson
    August 25, 2009 at 11:42 pm
    Yes, I never said HQ, what a waste. These guys here know what I’m talking about, if you have fast enough drives and enough of them you are much better off going this way. BTW FW 800 Raids seem to be fast enough to process a couple of streams of 1080 ProRes, I use a SATA array, which is more than fast enough, even on my MBP.
  • Teague Fleury
    August 26, 2009 at 12:29 am
    yeah, like i said originally, i am still learning so I wasn’t quite sure if ProRes HQ was necessary. Now that i know it’s not, i am excited to be able to capture more efficiently and know that i am on the right path.
    The moral of the story is that i should capture using ProRes, edit all my footage (60i and 30P) in a 30P timeline at original size of 1440 X 1080, and then scale to 1920 X 1080 when finished. I guess there is nothing left to do but start capturing!!!
    I can’t thank you guys enough for all your help, it means a great deal to me.
    -Teague
    NOMAPSfilms.com
  • Dan Nocera
    August 28, 2009 at 5:04 am
    If Teague shot in HDV isn’t the regular Pro Res codec even over-kill? I thought the new Pro Res LT was the best choice for transcoding from HDV because its just about double the bit rate of HDV – 50Mbits. Of course I’m assuming Teague has FCP 7. . .
    Another thought- If you want the 60i footage to look its best you should de-interlace it using compressor instead of de-interlacer in FCP. You can batch convert all of the footage after you have captured it. Just pull the footage into compressor and use the quicktime pro res preset. In the third tab in the inspector turn the frame controls on. Set the OUTPUT FIELDS to progressive and deinterlace to better (or best if you have a few days free for rendering) Un-check adaptive details.
    I’ve found that compressor does a better job of deinterlacing(set on better or best) than FCP. Final cut will deinterlace the 60i footage simply by pulling it into a 30P timeline but it will be the equivalent of compressor’s FAST(Line Averaging) setting . . .
    There are plugins that you can also use in FCP like Nattress Smart Deinterlace instead- but you have to render to playback.
    Dan Nocera
    CTFCPUG Moderator
    If all else fails give it a whack!!
    -Anonymous Techie
