Activity › Forums › Avid Media Composer › “You have only 50 minutes left on this drive…” ?
  • “You have only 50 minutes left on this drive…” ?
    Posted by Ron on April 26, 2005 at 12:15 am
    Hi –
    Just joined CC. Glad to be on board, after being an Avid editor for some number of years now.
    I am running two systems, one is a Meridian-based system on a Mac. Recently, it started to do
    this “weird thing.” When digitizing, it tells me, “You have only 50 minutes left on this drive,
    would you like to change drives now?”
    I have never encountered this sort of error before. Of course, with 50 minutes left on a drive,
    I would NOT want to change.
    I ran various Mac utilities on the main HD and ran Avid utilities; none returned any obvious
    errors or problems.
    Any thoughts?
    Thanks.
    Ron
    TheAmericanRoadside
    https://www.theamericanroadside.com
    WhatACollection.com
    https://www.whatacollection.com
    Ron replied 21 years, 5 months ago 3 Members · 3 Replies
  • Tae
    April 26, 2005 at 2:20 am
    Have you tried going into the media creation setting or digitize settings? See if something funky is switched on?
    -T
  • Jon Zanone
    April 26, 2005 at 11:29 am
    Welcome! I hope the cow is as helpful to you as it is to me!
    There is a setting that will notify you how much time is left on your drives. The default is 2 minutes. I suspect someone got in there and started mucking around with it. I believe it’s in the digitize settings.
    Jon
  • Ron
    April 26, 2005 at 2:09 pm
    I am pretty sure I already checked all the digitize settings. However, I’ll look again
    and see if I missed anything.
    Also, maybe I should try doing this with another user’s settings, to see if mine
    got splattered…
    I’ll let you know if any of this helps.
    Ron
    TheAmericanRoadside
    WhatACollection.com
