Activity Forums Adobe After Effects You guys are my final hope (Jpg damge)
  • You guys are my final hope (Jpg damge)
    Posted by Gabe Topete on September 15, 2008 at 8:15 pm
    Hi guys!
    I want to know of a way to damage jpgs like so
    https://www.kvi.nl/~kroon/lightroom/corrupted.jpg
    Also I want to know how to do the same thing to a quick time movie.
    I found a good way to damage a jpeg by opening the file in textpad and changing the code, but when I do the same method for a movie file it just freezes. Any thoughts on how to pull off a good corrupt file look.
    also I know there is a website that has images of corrupt Jpegs but I lost the link if anyone has this link I wold be SO HAPPY.
    Thanks all.
    Nick Vitello replied 17 years, 12 months ago 5 Members · 7 Replies
  • 7 Replies
  • Nick Vitello
    September 15, 2008 at 8:38 pm
    If you wanted to create this manually in After Effects you could use a displacement map to get that corrupted image jag.
    Or duplicate the image and use a combination of masks and adjustment layers to add the jags and color tint changes where you want them to appear.
  • Darby Edelen
    September 15, 2008 at 8:39 pm
    I think you’re going to have to try to fake the corrupted look for a movie file. JPEGs are easy to corrupt through a text program (as you’ve found) but a movie has a whole lot of information in there that is essential to playback. You can achieve that basic look through After Effects fairly easily using some distort/displacement and color ‘correction’ techniques.
    Try throwing one of the ‘Bad TV’ effects presets on your footage as a starting point if you’re lost.
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Gabe Topete
    September 15, 2008 at 9:02 pm
    Thank for the tips guys.
    Still would like to figure that website with gallery of damaged Jpeg images 🙂 I hate web hunting
  • Chris Wright
    September 15, 2008 at 11:51 pm
    You could re-create that effect with a simple precomped mask and transform x offset with hue/sat.
  • Gabe Topete
    September 16, 2008 at 12:55 am
    this is a better example
    https://thekuipers.org/images/IMG_2279.jpg
    what I am doing is the “messed up” camera effect like in cover field. At certain points the video has this corruption look to it.
    I saw a while back some on this forum posted a way to do this and alink to a site with images like above.
  • Dave Fraser
    September 16, 2008 at 9:02 am
    maybe a little long winded, but you could export your video as a jpeg sequence and then manually corrupt your jpegs in text edit as you mentioned earlier. if its only a couple of seconds here and there, hopefully it shouldn’t take too long.
    Dave Fraser
    Motion Graphics Artist
    Big Button
    http://www.bigbutton.tv
  • Nick Vitello
    September 16, 2008 at 2:45 pm
    Do you want this effect for video or just for still images?
    If you want this effect for video I highly recommend the Twitch plugin from Videocopilot:
    https://www.videocopilot.net/products/twitch/
    It comes with the plugin and tutorials on how to use it. This will definitely give you that Cloverfield effect. It’s terrific.
