Activity Forums VEGAS Pro Yikes: Mask hides all other video on all timelines
  • Yikes: Mask hides all other video on all timelines
    Posted by Don Hutcheson on December 23, 2013 at 1:51 pm
    I am using an effects mask (Digital Juice). It worked great at first, but I might have accidentally changed a setting because now the only video visible is the parent/child track. The rest becomes visible when I mute the effects track, but I want to use that track. When the effects track is active, the other video tracks won’t play in the preview monitor or render. Thank you!
    Hutch
    John Rofrano replied 12 years, 4 months ago 2 Members · 1 Reply
  • John Rofrano
    December 23, 2013 at 2:54 pm
    [Don Hutcheson] ” It worked great at first, but I might have accidentally changed a setting because now the only video visible is the parent/child track. “
    Are you sure it worked before? You may have changed the parent/child relationship which is causing the other tracks to be hidden. If not…
    That’s the nature of compositing. It affects ALL of the tracks below it. That’s why programs like After Effects use multiple comps. You have several options in Vegas Pro:
    (1) Do your compositing in another project and drop that project into your main project as a “nested” project. This is the most desirable way to address this. It exactly mimics nested comps in AE and it is the primary reason for using nested projects in Vegas Pro.
    (2) Move your composite track lower in your project so that the only tracks below it are the ones you want to composite with.
    (3) Place White Generate Media on the Mask track so that the video below it will show through. This is the least desirable because it will cause render times to increase significantly because your entire project becomes a composite.
    I would strongly recommend option 1.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
