Activity Forums Apple Final Cut Pro Yield Sign!
  • Yield Sign!
    Posted by Patrick Donegan on December 12, 2015 at 3:22 am
    I have the Yield sing over an icon in the Libraries viewer.
    I just reconnected the slides (image files)
    the yield is still there.
    Also, there is one over a different Library name.
    Is there a place to see where all these error messages are hiding so I have a clue
    on what to fix?
    Craig Alan replied 10 years, 8 months ago 4 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    December 12, 2015 at 5:48 pm
    If everything is actually relinked, then a restart of the app usually gets rid of the caution sign.
  • Patrick Donegan
    December 14, 2015 at 1:51 am
    argh – the Yield sings are still there!
    How do I find out what they are referring to?
    FCP X 10.2.2 – user since FCP 1.25
    iMac mid 2011, MBA mid 2012
    HVX-200, Shure wireless mic
  • Jeremy Garchow
    December 14, 2015 at 1:55 am
    Something is still offline. You could look in the browser and see if you see a red offline sign, or select the library and choose File > Relink Files and select the radio button to “missing” and see if X reports which files are still missing.
  • Patrick Donegan
    December 14, 2015 at 2:05 am
    Thanks – I will check that way again.
    I made the mistake of “organizing ” some slides, but in the finder in the Project library ..
    and then now there are many errors, even after I put the files back into the top level of
    And I read that sometime it means a project has not finished rendering ….
    I really wish I could right click and show the error reason..
    and while we are at it, it is none of these:
    https://support.apple.com/kb/PH12711?locale=en_US&viewlocale=en_US
  • Jeremy Garchow
    December 14, 2015 at 2:11 am
    What does it look like? A yellow sign with an exclamation point?
  • Patrick Donegan
    December 14, 2015 at 4:15 am
    Let me see if I can attach a screen shot:
    9561_screenshot20151213at6.05.25pm.png.zip
    /Users/patrick/Desktop/FCPX yield .png
  • Jeremy Garchow
    December 14, 2015 at 4:28 am
    Yes. That’s media offline.
    In the Browser, do you see any red clips that are offline?
  • Patrick Donegan
    December 14, 2015 at 9:38 pm
    Nope – I don’t see any media that is off line in those clips.
    It could also be that the rendering is not complete.
    I really wish I could just right click and see where the error are.
  • Jeremy Garchow
    December 14, 2015 at 9:56 pm
    [Patrick Donegan] “Nope – I don’t see any media that is off line in those clips.”
    If you select the event and chose File > Relink Clips and click the “Missing” Radio button, are there any clips listed?
  • Doug Metz
    December 15, 2015 at 2:09 pm
    I have seen the the Offline indicator on my setup with all media connected – it turned out to be a missing transition. I’d been cleaning up my effects / transitions / generators (removing demos, etc.), and I had inadvertently left a demo transition in one of my projects.
    Something else to check…
    Doug Metz
    Anode
