Activity › Forums › Blackmagic Design › Yet another workflow question
Posted by Daniel5000 on June 23, 2007 at 8:45 pmHello
Well, the posts on this seem varied and dependent on how individuals work. So it might be a bit too much to expect a consensus view.
I
Deleted User replied 19 years, 3 months ago 2 Members · 3 Replies -
Deleted User
June 24, 2007 at 12:02 amHello Daniel,
I would capture if working on the MAC to the Apple’s Quicktime MOV format to Blackmagic codecs. You can them use Automatic Duck software to open your Apple Final Cut Pro timeline into Adobe After Effects.
Then export back to the Blackmagic design codecs. You can then open the video files on your Microsft Windows Machine and then edit/export all the clips as they will be using the Blackmagic codecs so these can be both used on a MAC and PC systems.
It would be easier then having to export to Photo Jpegs and other formats. The the Alpha channels inside of After Effects, you could export to Blackmagic codecs, then export a seperate alpha channel matte version. Then in your editor etc combine the video clip and the matte and use the matte to create the punch out.
Hope that helps?
Leo
Daniel5000
June 29, 2007 at 7:35 pmLeo
Many thanks for your response. Unfortunately, I have been very busy and not have time to reply. So..my apologies
Ill do some test with your suggestions.
Again Many Thanks
D -
Deleted User
June 29, 2007 at 7:37 pmHello,
No worries, let me know how you get on with it.
Have a great weekend!
Leo
