Activity Forums Apple Final Cut Pro Legacy Ye old export problems.
  • Ye old export problems.
    Posted by Steffen Hedeby on April 29, 2010 at 11:45 am
    Hi everyone.
    I have been looking at the Cow for a while now and though there are many useful comments and answers I haven’t been able find a solution to my problem.
    If there is a topic on this problem I would appreciate a redirect.
    Ok first things first.
    I use a 2.33 Ghz intel core2 duo Macbook pro with 2 gb 667 Mhz DDR2 SDRAM.
    I run Final cut studio 3 with Final cut pro version 7
    Quicktime Pro version 7.6.6
    My cam for this project is the Go Pro Hero HD
    My workflow so far is this.
    Shot some footage at 1280x720p, 16:9 @ 60 fps60. Mpeg 4 movie file in H.264 and AAC.
    “Captured” it to my desktop. Played it on QT and it looked awesome, well as awesome as you could expect from this kind of cam.
    Then I used compressor to convert the footage into Apple ProRess 422 HQ progressive with AAC.
    Imported this into FCP and it still looked good.
    Made my edits and exported it as a QT ref movie with same settings chosen and unchecked make movie self contained.
    Then imported in compressor and used the vimeo.com guideline to set up compressor. The result was this: https://vimeo.com/11303760 Not so impressing as before when it was just an mpeg 4 file or the ProRess file. The movie gets sort of pixelated when there is movement an thats not the point of a helmet cam. By the way I have see very impressive Go Pro HD footage on the web.
    I the tried to export from FCP using quicktime conversion with an h.264 with current framerate and a keyframe at every 30 frames, limited to 5000 kbits/sec optimized for download, on best quality, size set to match my clip. and multi pass chosen. Dimensions set to 1280×720 HD preserve aspect ratio and de-interlaced unchecked. Sound is AAC 128 bit at 44.100 khz
    But this did not sort my problem as the file still looks pixelated and blurry.
    I have tried to play the file on both VLC and QT pro(with use high quality when available enabled) with same result.
    I have also tried viewing the online file on both PC and MAC in a variety of different browsers.
    So now for my question. What am I doing wrong? Can anyone se where in my workflow i make the mistakes and if so steer me in the right direction?
    I you should need more info please just let me know!
    Any help will be very much appreciated!!
    Best regards
    Steffen
    Cole Prine replied 16 years, 4 months ago 3 Members · 3 Replies
  • Rafael Amador
    April 29, 2010 at 1:17 pm
    Hi Stephen,
    Sometimeswe find very bad guidelines.
    Why to set manually the K-frames?
    What cue have the people to chose 10 or 20 or 30?
    Let it Automatic.
    One of the purposes of a “multi pass” is to let the compressor optimize the K-frames.
    If you set it manually you screw this.
    rafael
    http://www.nagavideo.com
  • Steffen Hedeby
    April 29, 2010 at 1:55 pm
    Hi Rafael,
    Thank you for your reply!!
    I tried it but unfortunately it did not solve the problem with quality loss (slight pixelation and blurriness).
    I still get the same result as with my previous setup.
    Best regards
    Steffen
  • Cole Prine
    April 29, 2010 at 2:59 pm
    When I’m uploading to Vimeo, as long as the video isn’t really long, I just export an H.264 quicktime and upload that. Usually looks great. Just open the reference video in quicktime and go to File~Export – then set your compression to H.264, quality at High, the under size, just use current settings. Then you can upload that quicktime to vimeo. I do it weekly.
    Cole Prine
