Activity Forums Adobe Premiere Pro YC Waveform discrepancy with PPRO 1.5
  • YC Waveform discrepancy with PPRO 1.5
    Posted by Rex Summerfield on October 18, 2006 at 8:43 pm
    I’m working on a broadcast project requiring an IRE between 100 and 7.5. I went through and adjusted each clip with the brightness/contrast effect. Everything looks great on the YC Waveform monitor until I nest the project sequences together on the master timeline. A quick check with the YC monitor shows my highs near 110 IRE on the master track. Checking the original shows proper levels. I know the PPRO monitor is not the most accurate but it should at least be consistent. Has anyone else run into this?
    Rex Summerfield
    Shiloh Outdoor Productions
    Vince Becquiot replied 19 years, 11 months ago 2 Members · 1 Reply
  • Vince Becquiot
    October 19, 2006 at 6:25 am
    I did notice that a while back. It actually appears that the brightness and contrast filter just doesn’ t get past on to the new nested sequence. A big bug ? It sure seems like it….
    You could use levels instead, it will actually give you much more control, and it does work in the new sequence.
    Sorry, just a workaround here….
    Vince
