Activity Forums Apple Final Cut Pro Legacy Yamaha Mixing Desk
  • Yamaha Mixing Desk
    Posted by Philip Scaife on January 7, 2008 at 8:33 pm
    Hi all,
    Just purchased a mixing desk, Yamaha MG12/4, which is my first mixer. Check it out:
    https://www.gbaudio.co.uk/data/yamaha/mg12.htm
    We use these at work but on PC’s and Avid’s so this is no help to me as I struggle to set it up on my Mac.
    So my question is does anyone have this desk and is using it with FCP and if so could you lend me a few pointers on what I may need and how to set it up. I was thinking maybe a breakout box or something. Anyways you know best I’m sure.
    Cheers, appreciate any help
    Phil
    run FCP 6 on Mac Pro
    Adam Taylor replied 18 years, 8 months ago 2 Members · 1 Reply
  • Adam Taylor
    January 7, 2008 at 11:17 pm
    it all depends on what you already have connected to your mac (ie-what video card, what tape decks, etc) and what you actually want to use the mixing desk for.
    I don’t ever remember seeing a mixing desk actually used for mixing on a non linear system – thats either done in the box or sent over to Protools (or some other audio package.
    Usually its to provide flexible audio monitoring, and occasionally to allow levels to be set with a fader when digitizing off or laying back to tape. However, that is also dependant on the signal you are sending or receiving….if analogue, then your desk is fine, whereas if its a digital signal such as from a digibeta then you would be better leaving the audio signal embedded within the sdi video and letting a decent video card (such as the Kona’s) handle the audio.
    This is what i do – the kona 3 handles all the audio from digibeta, and all the monitoring is done by taking an analogue feed from the stereo rca plugs on the kona breakout box into the Mackie Big Knob (essentially its a small mixer without all the faders). As the mackie has several inputs I can also feed my Protools rig into it and monitor through the same loudspeakers.
    Tell us what you have and what you want to achieve and you’ll probably get some useful suggestions.
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
