Activity Forums VEGAS Pro Xvid rendering aspect ratio proroblem
  • Xvid rendering aspect ratio proroblem
    Posted by Yuriy Niksych on May 14, 2014 at 5:54 am
    Greetings! This is weird, I did not have this issue before. I am using sony vegas 12.
    When I try to render to avi (xVid) (in my case, 1920×1080), the resulting video is very thin/squished (I do not know the actual resolution, but it’s something around 230×1080).
    https://i.imgur.com/Cy0tkKP.jpg
    What’s more, if I open this file with MPC Classic and select the option “view->video frame->stretch to window” the video is now normal and in Full HD – however when I upload to youtube it is still squished.
    Checklist:
    1. The project properties are set to 1920×1080, pixel aspect 1.0
    2. In Render As->customize template, pixel aspect is 1.0, and frame size is “use project settings” (I’ve also tried 1920×1080 but it made no difference)
    3. disabling “maintain aspect ratio” on the video, and also enabling “stretch window to fit output size” didn’t help
    I’m running out of ideas, pleas help!
    View post on imgur.com
    Steve Rhoden replied 12 years, 4 months ago 3 Members · 4 Replies
  • Graham Bernard
    May 14, 2014 at 10:16 am
    Something in your workflow is NOT retaining the aspect ratio. Now, that’s either the render template and/or the CODEC you are employing.
    Try this:
    1/- Match your Settings to your media. Do you know how to do that?
    2/- Use a plain vanilla Render template that you’ve used before.
    BTW, have you downloaded any CODEC Pack?
    Grazie
  • Steve Rhoden
    May 14, 2014 at 10:29 am
    Seems you simply need to go into the XVID customize settings during
    rendering and make an adjustment.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Yuriy Niksych
    May 14, 2014 at 6:26 pm
    Thanks guys you are awesome! the problem was indeed in the Xvid Settings
    in customize template->Xvid Settings -> click “more” near profile@ level->aspect ratio
    I clicked the “default” button (square 1:1), now works like a charm!!!!
  • Steve Rhoden
    May 14, 2014 at 11:08 pm
    You are welcome, Glad it worked.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
