Activity Forums Apple Final Cut Pro Legacy Xserve bonding + network Vlan
  • Xserve bonding + network Vlan
    Posted by James Kennedy on June 25, 2012 at 9:26 am
    Not sure if this is the correct forum for this apart from asking users if they have had a similar experience, the problem is Xerver which has its Ethernet ports bonded and we were using the Xserve as server to 5 powermacs and was working OK for SD editing but recently we have “dropped frames” issues, followed FCP 7 advice on preventing this but it still occurs, the only other modification done to the network was Vlans were setup as a network security measure, could this be causing the issue.
    James Kennedy replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
