Activity Forums Maxon Cinema 4D Xref Location Moved
  • Xref Location Moved
    Posted by Tom Slattery on January 14, 2015 at 7:32 pm
    Hi!
    My directory of Xref objects has moved to anther location on the HD. What results is all Xrefs (legacy) in my scene files – which are many – point to the old directory. Therefore, a lot f part kissing when opening the scene.
    Is there a find/replace method out there to update the Filename path for all refs in one shot?
    ~TPS
    Tom Slattery replied 11 years, 8 months ago 2 Members · 2 Replies
  • Brian Jones
    January 15, 2015 at 2:26 am
    with the Exchange command in the XRef Manager you can select some (or all) the xrefs (in the manager) and choose a new folder.
  • Tom Slattery
    January 15, 2015 at 4:13 am
    Exactly what I hoped there was, just buried in a menu.
    Thank you! You Rock.
    ~TPS
