Activity Forums Maxon Cinema 4D XPresso vs. the Hair module
  • XPresso vs. the Hair module
    Posted by Gage Ullman on September 29, 2010 at 8:05 pm
    So I have a scene set up with a spline that animates using an XPresso tag, and then used as the path of a sweep NURBS. The main purpose of the sweep nurbs is to knock around some hair in a certain way. I just spent the morning trying to figure out why my object, collider tag applied, was passing right through the hair. I did other experiments, added colliders to other objects, they passed right through the hair as well. I copied the other objects and the hair into new projects, and they worked like gangbusters. As soon as I took the collider tag OFF the Sweep NURBS with the XPresso tag, everything ELSE reacted with the hair just fine.
    SO. Anyone know if there are known issues about XPresso conflicting with Hair? And if so, is there a workaround?
    Brian Jones replied 15 years, 11 months ago 2 Members · 1 Reply
  • Brian Jones
    September 30, 2010 at 3:03 am
    can you post one of the tests?
