Activity › Forums › Maxon Cinema 4D › xpresso – transfer a user data In-/Exclusion list to link list node?
  • xpresso – transfer a user data In-/Exclusion list to link list node?
    Posted by Pryce Duncalf on March 20, 2022 at 3:43 am
    Hi. I am trying to access a user data list in the xpresso using a link list node so I can individually edit the different items in the list. There is no input into the link list for this. Is this possible? or would I need to use python to rebuild the node (which is very much out of my specialism). Any help appreciated!
    Regards. Pryce.
    kieran gee replied 3 years, 3 months ago 2 Members · 2 Replies
  • Pryce Duncalf
    March 21, 2022 at 11:13 am
    This was solved on another forum with a simple bit of python:
    import c4d
    def main():
        global Output1
        if InEx is None:
            Output1 = None
        if Index < 0 or Index >= InEx.GetObjectCount():
            Output1 = None
        else:
            Output1 = InEx.ObjectFromIndex(doc, Index)
  • kieran gee
    June 30, 2023 at 1:21 pm
    Hi Pryce
    Would you mind sharing how you implemented this workaround?
    I am having the same issue, all I’d like to do is link my user data list to the list in xpresso.
    Kieran
