Activity Forums Maxon Cinema 4D Xpresso TP problems with a simple (?) solution?
  • Xpresso TP problems with a simple (?) solution?
    Posted by Chris Mcmillan on February 22, 2018 at 9:44 am
    Hi!
    I’m trying to import a particle animation and apply the ‘pscale’ attribute that is in the simulation to set the size of my objects. I’ve never really used Xpresso before and I am having issues making it work all together. I’m guessing I’ve just missed something basic.
    Here is a screenshot of what the setup looks like:
    https://i.imgur.com/c0daq2e.png
    I’ve used a PStorm emitter (I’m not sure I need this since my imported particles are already being emitted?). I have attached the imported particle group to ‘Particle Geometry’ but it is not emitting the geometry (Cube) nor applying pscale.
    Any ideas? I have attached the scene if you want to see it for yourself.
    Many thank yous!
    https://www.dropbox.com/s/hfsrvxkklscwxzl/Import_TP.zip?dl=0
    View post on imgur.com
    Chris Mcmillan replied 8 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    February 23, 2018 at 3:10 am
    yes simple. You use a PPass not a PStorm and you don’t need a Particle Geometry – then the PPass feeds the Shape the GetData and a Setdata like this…
    12198_importtp.zip
  • Chris Mcmillan
    February 23, 2018 at 7:59 am
    Oh wow, what a life saver! Thank you so much!
