Activity Forums Maxon Cinema 4D XPresso-Sound Operator Audio Export?
  • XPresso-Sound Operator Audio Export?
    Posted by Michael Taylor on June 7, 2010 at 1:47 pm
    I’m working on a project that requires me to have animations trigger different sound files. Using the sound operator in Xpresso, I have a simple and successful set up where a boolean check box is checked and the sound file plays within Cinema 4D. Once I get my main set up complete, I want my render from Cinema 4d to include the audio that is triggered in Xpresso from a few different sources.
    However my renders don’t include the audio. I have the checkbox activated in the render settings “Include Sound” and I can get C4D to render audio once you add it as a specialty track to an object in the timeline.
    They key to this is being able to use Xpresso to decide what sounds are played and when, it will save me a ton of time and quite possible make this project doable in the end. If anyone knows how to get rendered sound using the SOund Node I would greatly appreciate some help. Thanks.
    Michael Taylor replied 15 years, 9 months ago 1 Member · 1 Reply
  • Michael Taylor
    November 11, 2010 at 6:34 pm
    I’m going to bump this…I am still looking for any help out there on this. I picked up my project again and I’m still stuck with this. Has anyone had success with exporting sound in Cinema 4D?
