Activity Forums Maxon Cinema 4D XPresso Question – On/Off depending on direction
  • XPresso Question – On/Off depending on direction
    Posted by Tony Barone on April 26, 2013 at 1:46 pm
    New day, new problem!
    I have a pretty simple animation setup with some Xpresso Nodes which turn a screw and move it along it’s Y axis at the same time.
    I have two sets of arrows on a ring to also indicate wether the screw is turning clockwise or counterclockwise.
    Currently I have a User Data switch to control the visibility of either arrow.
    Is there a way to setup something in my Xpresso Nodes which would turn on the visibility of the appropriate arrow when the User Data (Float slider) is increasing from 0% – 100% (and turning the screw clockwise). And then turn on the other arrow when moving the slider from 100% to 0%?
    Tony Barone replied 13 years, 4 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    April 26, 2013 at 4:28 pm
    Another good puzzle! 😉
    The key here is the Memory Node which allows you to look back in time and determine a parameters value in the past. Once you get that past value it’s just a matter of subtracting the it from the current value. Based upon whether the result is negative or positive you can tell if the object is rotating forward or backward.
    File: 5920_rotationdirectioncontrolsvisibilitymemorynode.c4d.zip
  • Brian Jones
    April 26, 2013 at 4:46 pm
    try using a Memory node to remember what the slider value was last frame then subtract one from the other and change the arrow depending if the answer is positive or negative – edit – Adam got there first 🙂
  • Tony Barone
    April 26, 2013 at 6:05 pm
    Thanks Adam! Perfect! No way I would have figured that one out.
