Activity › Forums › Maxon Cinema 4D › XPresso Question – 1 % Slider controlling 2 “Real” Number others
  • XPresso Question – 1 % Slider controlling 2 “Real” Number others
    Posted by Tony Barone on September 10, 2012 at 2:10 pm
    I have an XPresso question, an please note, I am rather new to XPResso in general.
    I am trying to setup a Float Slider which will control 2 other Float Sliders, which in turn will move 2 separate objects different distances at the same time.
    Slider 1 – is set for Percentage 0 – 100%
    When Slider 1 is at 0%, Slider A and B should be at 0 (REAL)
    When Slider 1 is at 100%, Slider A should be at 70 Real and Slider B at 744 Real.
    I am assuming I need to put a Node in between the connections from Slider 1 to A and B, but I just can’t figure out what to put in-between.
    Any help would be greatly appreciated!
    Tony Barone replied 14 years ago 2 Members · 4 Replies
  • Brian Jones
    September 10, 2012 at 2:24 pm
    why have one slider control two others why not just have the one slider control both objects directly?
  • Tony Barone
    September 10, 2012 at 2:43 pm
    My reason for not having the one slider move the two objects directly is that the two objects move different distances, in real numbers.
    They both start at 0, but when the slider is at 100%, Object A should be at x: 70 and Object be at x: 744
    If theres a way to do this with one slider, that would work for me too!
  • Brian Jones
    September 10, 2012 at 3:42 pm
    the Range Mapper node is what you are looking for. It would be possible to control two sliders from one by having the master sliders value go through two range mappers to the slave sliders but it’s simpler to just have the range mappers plug straight into the target objects.
    4638_slidercontrols2things.c4d.zip
  • Tony Barone
    September 10, 2012 at 6:42 pm
    That is great! Thank you so much for your help!
    Unfortunately I don’t think this method will work with my current project. The one object needs to “step” from each position in X:10 incumbents while the second object moves smoothly. Theres probably a way to work that into XPResso, so if I have more time I will definitely look into it.
    Thanks again!!
