Activity Forums Maxon Cinema 4D Xpresso Memory Node not showing up when rendering.
  • Xpresso Memory Node not showing up when rendering.
    Posted by Euan Preston on August 4, 2011 at 3:50 pm
    Reasonably new to C4D and I’m having a weird issue using a Memory Node.
    I have an object (a butterfly) which I’ve animated so that it’s wings flap.
    In order to save on keyframes, I’ve set up a Null object which I’ve connected through Xpresso to drive the wings. I’ve also used the same Null to drive the position of the body as well as a bend deformer so that I have a nice natural bend in the wings.
    In order to achieve natural looking movement, I’ve set up a Memory Node between the Null and the body / bend modifier which delays the effect of the driver. It all looks great in the Editor window, however when I render to picture viewer, the Memory Node has no effect at all.
    Any advice very much appreciated.
    Cinema 4d R12.0 on OS/X Leopard
    Euan Preston replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
