Activity Forums Maxon Cinema 4D xpresso for animating an umbrella
  • xpresso for animating an umbrella
    Posted by Renaud Hericord on September 3, 2012 at 3:46 pm
    Hi Everybody
    i hope everybody is ok, thank you very much for your grateful help !
    i am doing an umbrella with joints for the main structure, i did a user data to open and close it, but i would like to link an object that will move according to the percentage of my user data
    if my user data is between 0 and 50 i would like my object to be between (Global Position Y) -58,825 for 0% and -44,108 for 50 % and finally going to -13 for 100%
    i am trying to do it with the logic nodes but i am not an expert at all with xpresso and grrrrrr i am lost
    Can someone help me ?
    Brian Jones replied 14 years ago 2 Members · 2 Replies
  • Renaud Hericord
    September 3, 2012 at 5:21 pm
    I found my solution with a range mapper and the use spline in the range mapper but if someone has the solution with compare condition nodes…
  • Brian Jones
    September 3, 2012 at 7:09 pm
    do you want a smooth transition from 0 to 50% and then wait and snap at 100% or just a different rate from 51 to 100%?
