Activity › Forums › Adobe After Effects › XML Parsing problem (with XML Object)
  • XML Parsing problem (with XML Object)
    Posted by Tomasz Tejchman on July 16, 2012 at 10:35 am
    Hi there!
    I need to parse GPX data to create a new composition. It’s actually just a XML file with GPS data.
    Here is an example how I create XML object:
    var myFile = File.openDialog("Choose GPX file","*.*");
    function readXMLFile(file) {
    if (!file.exists) {
    throw "Cannot find file: " + deodeURI(file.absoluteURI);
    file.encoding = "UTF8";
    file.lineFeed = "unix";
    file.open("r", "TEXT", "????");
    var str = file.read();
    file.close();
    return new XML(str);
    var ch = readXMLFile(myFile);
    ch return whole XML file and it’s OK. Unfortunately when I try to retrieve a children nodes it returns nothing.
    Below is my XML file.
    <?xml version="1.0" encoding="UTF-8"?>
    I found there is an elements() function but it works strange.
    Tomasz Tejchman replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
