Activity Forums DaVinci Resolve XML mixed formats
  • XML mixed formats
    Posted by Eri Levin on June 12, 2014 at 3:27 pm
    Hello,
    I have an XML file with a timeline that has mixed formats mainly:
    1. EXCAM 1920×1080 23.98
    2. HVX200 1280×1080
    3. Gopro 1920×1080
    4. Dslr clips
    No Matter what settings I pick on Resolve I cant get a timeline correctly imported. I either get squeezed footage or cropped or black bars etc. I never had to deal with mixed file formats. Can anyone offer any advice?
    Marc Wielage replied 12 years, 3 months ago 3 Members · 2 Replies
  • Stephen Smith
    June 13, 2014 at 5:40 pm
    I thought DaVinci didn’t support RAW Sony EX cam or P2 footage? Did you convert them to some other codec? This is why I have found it is easier to edit the RAW footage and then export out a clip of the full edited piece and then do the auto scene detection. DaVinci does an amazing job.
    To change a clips aspect ratio you can Right click on the clip in the EDIT window. Choose Clip Attributes in the drop down menu and change the Pixel Aspect Ratio. You’ll probably want DVCPRO HD. However I have had trouble with P2 footage shot at 1888 x 1062 which is why I prefer to just export out my completed video and do the scene detection. Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Marc Wielage
    June 14, 2014 at 4:01 am
    If the end result is all 1920×1080 HD, then I’d convert all the clips in advance to a common format like ProRes 422 HQ — I’m not sure 444 will buy you anything for 8-bit material like this — and then bring the ProRes copies into daVinci Resolve. Mixing weird camera formats on the same timeline is theoretically possible, but fraught with problems.
