Activity Forums DaVinci Resolve XML import
  • XML import
    Posted by Graham Ernest on July 23, 2011 at 3:45 am
    Trying out Resolve to see if it will be our replacement for Color. Imported XML from FCP 7, when it brings in my sequence everything is there, but the clips are not in the proper order. Am I doing something incorrectly, does FCP make bad XML, or does Resolve not interpret FCP XML correctly?
    Joseph Mastantuono replied 15 years, 1 month ago 5 Members · 5 Replies
  • Kim Krause
    July 23, 2011 at 8:03 am
    i have the same problem…apparently it comes down to how you recomform in davinci before you grade….i’ll be keeping an eye out for a solution from someone with experience in this….
  • Rohit Gupta
    July 23, 2011 at 10:46 am
    Could you please send your XMLs to davincihelp (at) blackmagic-design.com, and we’ll take a look at the XML?
    Rohit
  • Graham Ernest
    July 23, 2011 at 1:54 pm
    I will send it Monday morning when I get back into work.
  • Nate Weaver
    July 23, 2011 at 6:47 pm
    An A/C sort order issue maybe?
    Nate Weaver
    Director/D.P., Los Angeles
    https://www.nateweaver.net
  • Joseph Mastantuono
    July 23, 2011 at 9:27 pm
    There is a “master session” which has all the clips, and your conform. In the conform window, make sure you’re actually on your sequence.
    I’ve done a few round trips with fcp7 and been very happy so far.
    Joseph Mastantuono
    Online Editor – Colorist – Post Consultant
    Brooklyn based finishing at reasonable prices
    917.969.1583
