Activity › Forums › Apple Final Cut Pro Legacy › XML Import & Open
  • Andy Mees
    November 22, 2005 at 1:25 am
    if you have a valid XML then double clicking should open FCP and initiate an Import > XML…
    if thats not happening it may be that your XML file is not “well-formed” (not structured correctly) or that your XML is not associated with FCP (you can use a utilty to change your XML file to an FCP XML file check out these… https://www.macupdate.com/info.php/id/18605)
    hope it helps
    Andy
