Activity › Forums › Adobe Premiere Pro › xml from final cut. reconnect all media?
  • xml from final cut. reconnect all media?
    Posted by Phillip James on November 18, 2012 at 2:25 pm
    my rusty old emac crashed so i pulled out the old hard drive so i can save all my old fcp projects. now I have moved to pc and built my own(so i can game as well). i now have premier pro and have converted all my projects from fcp into XML successfully but all my media must be reconnected. I know have to reconnect one at a time but my projects are HUGE!. is there a way to reconnect them all faster? auto connect from a file path or something? it would take about 4 hours to do it 1 clip at a time
    thanks
    Angelo Lorenzo replied 13 years, 10 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    November 20, 2012 at 6:53 am
    Is your footage in a single folders or a single hierarchy of folders? Or is it all spread across your hard drive in a ton of different folders?
    I ask because Premiere is usually very good about connecting files recursively. Find one file and it will connect other files in the same folder, the parent folder, the sub folders, etc.
    Try reconnecting one project and you may find that you’ll only actually need to reconnect a handful of files for each.
    Angelo Lorenzo
    Love my answer? Do me a huge favor and check out my Kickstarter project The Librarian, starring Jennie Garth of Beverly Hills 90210.
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
