Activity › Forums › Adobe Premiere Pro › XML file?
XML file?
Posted by Ron German on March 22, 2018 at 5:58 pmHi
I`m testing Black Magic Resolve 14 and it suposedly can import a Premiere Pro 6 project via XML a PP6 file.
But I can`t find the way to export this MXL file from my Premiere Pro 6 project (other than to Final Cut) .
Any help?
GerronStephen Smith replied 8 years, 6 months ago 4 Members · 11 Replies -
Stephen Smith
March 22, 2018 at 7:27 pmIt’s been a while since I’ve been on that version of Premiere. Isn’t it just: File, export, Final Cut Pro XML?
Stephen Smith
Check out my Vimeo page
Shane Ross
March 22, 2018 at 7:34 pmYup, that’s the option…on the bottom of the EXPORT list of options
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Ron German
March 22, 2018 at 7:58 pmWell, it seemed the import was not ok; maybe because it`s a XML for Final Cut Pro, not to Black Magic Resolve 14?
Shane Ross
March 22, 2018 at 9:43 pmI tested on my end…smaller Premiere Pro project, xported XML for FCP 7…imported that into Resolve 12.5…brought in the whole project, bins and all…and sequence.
Shane
Little Frog Post
Stephen Smith
March 23, 2018 at 3:14 amI export out FCP XMLS from Premiere all the time and have never had a problem bringing them into resolve. Did it import the file but it didn’t bring everything in or did it not ever import it at all?
Stephen Smith
Ronaldo German
March 23, 2018 at 1:19 pmI made another test putting several Premiere Pro 6 sequencies toguether (total 1 hour and 8 minutes).
Resolve 14 didn`t bring all the clips – I may understand this because a difficulty finding some folders – but brought aprox. 80% of the clips, and set them correctly.
The Premiere 6 individual clips audio adjustments wasn`t brought to Resolve 14 – the audio clips in Resolve are plain.
Resolve 14 also duplicate the Premiere 6 single R/L audio channels in some sequencies? !
Resolve 14 didn`t brought titles and charater generated clips – they are displayed as media off line.
The convertion also exchanged some clips that have the same number (I haven`t named all the clips – my fault) and are in different folders – I don´t know the criterion it used to do it.
Thanks -
Stephen Smith
March 23, 2018 at 5:26 pmAre you saying it brought everything you wanted into Resolve, it just showed 20% of the clips as missing and you will have to re-link them?
Stephen Smith
Ron German
March 23, 2018 at 6:32 pmYes. In fact, it was a mistake; there were aprox 5% missing clips that I`ll will have to re-link.
Thank you for your attention. -
Stephen Smith
March 23, 2018 at 7:03 pmBut everything else worked other than those 5% clips that you had to re-link?
Stephen Smith
