Activity Forums Apple Final Cut Pro Legacy XML and file extensions (FCP 6 to 5)
  • XML and file extensions (FCP 6 to 5)
    Posted by Scott Mills on January 8, 2008 at 11:58 pm
    I have been exporting XML (vers 2) files from FCP 6 to my older FCP 5.0 suite. It works fine, however FCP 6 doesn’t seem to use the file extensions (.mov) and FCP 5 does, so I end up having to relink every media clip manually.
    Is there any way around this? How do I get FCP 6 to use the extension, or get FCP 5 to not be so picky?
    Scott
    Scott Mills replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
