Activity Forums Audio XLR Microphone connection
  • XLR Microphone connection
    Posted by Tom Fino on August 6, 2015 at 7:05 pm
    I have a stage mic with an XLR connection that I want to use with a home stereo amplifier that has RCA inputs. Is there a way I can do this?
    Thanks.
    Eric Toline replied 11 years ago 3 Members · 2 Replies
  • Ty Ford
    August 6, 2015 at 7:59 pm
    Hello Tom,
    It depends on whether or not the mic requires Phantom Power. If it doesn’t, you can try an XLR to RCA cable. The problem there is that Mic Level is normally below that of the -10 level jacks on a home system, so you won’t hear much
    If the mic does require Phantom Power, you first need to buy an external Phantom Power supply or a small mixer with at least one XLR input that has Phantom Power. You’ll need a mixer with either a -10 output or a variable output that you can dial back some so you don’t overload the home system.
    What Mic?
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Eric Toline
    August 10, 2015 at 12:37 am
    If you have a dynamic microphone and a stereo receiver with phono level inputs you can connect the mic to the phono input and it will work just fine.
    “I push the RECORD button and hope for the best”
