Activity › Forums › Canon Cameras › XH-A1 / DTE Split Firewire Output?
  • XH-A1 / DTE Split Firewire Output?
    Posted by Chas Smith on May 20, 2010 at 7:00 pm
    I shoot conference / seminar video and I’ve a client who wants me to provide a firewire A/V out from my camera to his live webstream equipment. Problem is that my Canon XH-A1 firewire out will be connected to a DTE / Hard Drive Recorder like a Firestore or some equivalent. Correct me if I’m wrong but I seem to recall there’s only one firewire port I/O so I don’t believe you can daisy-chain the signal to some device like a “Telestream” or “NewTek”.
    Could I do a Firewire Hub between the camera and DTE? Would that work?
    Thanks in advance.
    Joel Servetz replied 16 years, 4 months ago 2 Members · 1 Reply
  • Joel Servetz
    May 22, 2010 at 3:20 am
    Look in markertek.com for firewire hubs and distribution amplifiers. Make sure you buy whatever additional cables you need with the right connectors (4 pin, 6 pin)
    Joel Servetz
    RGB Media Services, LLC
    Sarasota, Fl
    videobyjoel@aol.com
