Activity Forums Apple Final Cut Pro xf import plugin: canon bug or apple bug
  • xf import plugin: canon bug or apple bug
    Posted by Emiliano Tidona on April 20, 2012 at 11:13 am
    Hello,
    I’m using the new canon xf import plugin v. 2.0 to import my mxf files in fcpx. Everything ok except the retiming video quality: I can’t use Otical Flow for slow motion. I apply it and it seems to apply fine, fcpx analyzes the clip for optical flow but when it ends nothing change in the clip.
    If I import the same clip in fcp7 and then in fcpx, as I used to do before the release of the new import plugin, everything works fine.
    Someone else having this issue?
    Emiliano Tidona replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
