Activity › Forums › AJA Video Systems › Xena LHi not seeing analog
  • Xena LHi not seeing analog
    Posted by Alex Gerulaitis on July 16, 2009 at 11:43 pm
    Xena LHi is only showing SDI and HDMI in “Video Input”, and not showing any of the analog inputs, in either Machina or Premiere CS4. Drivers 4.1, Vista Business 64, HP Z800.
    “Primary Video Format” is 720×486 29.97i in both “Playback” and “Capture” options; “Analog Output” shows all of the standard analog outputs (Composite, component, etc.). It’s just that the analog video inputs have gone completely missing.
    What am I doing wrong? I’ll reinstall drivers 4.1, see if that helps, then install 4.0 – but maybe there is something very simple that I missed, in the configuration.
    TIA for any input (pun intended) 🙂
    Best,
    Alex,
    DV411
    Alex Gerulaitis replied 17 years, 2 months ago 1 Member · 1 Reply
  • Alex Gerulaitis
    July 16, 2009 at 11:50 pm
    AJA *very* quickly returned my call and said it’s a known issue and they will help me in my misery. 🙂
    Best,
    Alex,
    DV411
