Activity › Forums › AJA Video Systems › Xena LHe not seeing decks in Premiere or Machina?
  • Xena LHe not seeing decks in Premiere or Machina?
    Posted by Joe Gill on October 22, 2008 at 10:48 pm
    I am using these for ingest for compression – they worked fine for a while and the operators have updated to 3.5 drivers, and now the machines seem to be unable to control the decks using the regular 422 cables.
    I have uninstalled, gone back to 3.0.1 and come back to 3.5, run new test cables which also didn;t work, but tested all the cables with a DNF controller box, and now am stymied. Anybody got any thoughts?
    Joe
    Joe Gill
    Tim Kolb replied 17 years, 11 months ago 2 Members · 4 Replies
  • Joe Gill
    October 22, 2008 at 11:43 pm
    So I have removed the software using the uninstall as well as the remove, pulled the card and rebooted clean. I re-inserted the card in the machine (HP) and re-installed everything, and still no deck control…
    Joe Gill
  • Tim Kolb
    October 27, 2008 at 1:28 pm
    Can you see that RS422 deck remote is selected in Premiere Pro and Machina?
    This sounds like a software setting might have gotten flipped someplace perhaps…?
    TimK,
    Director, Consultant
    Kolb Productions,
    CPO, Digieffects
  • Joe Gill
    October 27, 2008 at 5:48 pm
    Restored system to working point, and still the 422 is unresponsive… Checked all the settings…
    Joe Gill
  • Tim Kolb
    October 27, 2008 at 7:34 pm
    Does Machina see the TC if you just manually press play? What format are you using and how is it coming in? (SDI/analog, etc…)
    TimK,
    Kolb Productions,
    CPO, Digieffects
