Activity Forums Apple Final Cut Pro Legacy XDCAM Transfer Tool Audio Issue
  • XDCAM Transfer Tool Audio Issue
    Posted by Andrew Wood on October 26, 2011 at 6:42 pm
    This past week I’ve been using the XDCAM Transfer Tool in FCP7. The footage is running off off a LACIE external. I had transferred some clips fine the last two days then suddenly now when I use the XDCAM Transfer Tool the clip I import the audio is all off a very glitchy (up and down in levels). Now I tried with a previous clip I had captured before alright and the same situation is happening now to all the material on the external. However if I preview in the transfer tool playback it appears to be fine, but once imported into FCP if just in the browser or putting it down on a sequence the audio is a mess.
    Andrew Wood replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
