Activity Forums VEGAS Pro XDCAM to hard drive
  • XDCAM to hard drive
    Posted by Allen Facemire on July 22, 2011 at 10:34 pm
    I have a PDW U1 which is pretty cool. With the limited supply of XDCAM discs, I’m wanting to give clients a hard drive with the material on it. If I make a clone, it takes longer than real time. Can’t I just slide the Clips or Subclips or both over to the drive and be assured the client has everything they need for the edit?
    1stcamera
    Atlanta, GA USA
    John Rofrano replied 15 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    July 23, 2011 at 1:28 pm
    [Allen Facemire] “Can’t I just slide the Clips or Subclips or both over to the drive and be assured the client has everything they need for the edit?”
    I would imagine that you could copy the entire disk into a folder on the hard drive and you’ll have everything you need. Don’t try and copy files out of the folder structure, just give them the entire directory tree starting from the root. Try it and see.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
