Activity Forums Apple Final Cut Pro Legacy XDcam to DV Pal Field problems
  • XDcam to DV Pal Field problems
    Posted by M. louise May on April 22, 2012 at 8:51 pm
    Hello!
    I’d like to ask for your advice in this subject:
    XDcam 1080 50i shot on EX 1, edit in FCP XDCam sequence, export a XDCam HD 422.
    I need a SD DV Pal copy of this, so I create a DVPal sequence, lower field first, and drop my XD movie there.
    Then I connect to an oooold DSR11 to print to DV tape.
    Problems: Field problems on DV sequence . I change from lower to upper field, field problem still there, in computer and also ext monitor.
    Any ideas what I’m doing wrong?
    Thank you, thank you, thank you!
    M. louise May replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
