Activity Forums Avid Media Composer XDCAM tab missing from import settings
  • XDCAM tab missing from import settings
    Posted by Jamie Mac on July 19, 2010 at 9:57 pm
    Is it me or is the XDCAM import tab within setting / import missing in 5.0.1. I’m sure it was there in 5.0.
    Cheers
    Jamie
    Kris Anderson replied 16 years ago 2 Members · 3 Replies
  • Kris Anderson
    July 19, 2010 at 10:09 pm
    It may have defaulted back to AMA settings. Check that AMA is off, re-launch MC and it should be there.
  • Jamie Mac
    July 19, 2010 at 10:13 pm
    Kris, thanks for the super fast response and that worked, turned off AMA and the XDCAM tab pops back up. Thank you so much for your help.
    Cheers
    Jamie
  • Kris Anderson
    July 20, 2010 at 12:12 am
    You’re welcome. The benefits of a global community… 24/7 help.
    Remember if you want to use AMA just do the reverse.
