Activity Forums VEGAS Pro XDCAM Rendering Problems
  • XDCAM Rendering Problems
    Posted by Bill Shepherd on April 15, 2011 at 11:34 am
    I am able to render individual clips with no problem.
    All the camera and Vegas settings are all the same.
    After placing and then saving the clips together on the Vegas Timeline, rendering begins as normal. Rendering stops anywhere between 10% and 95% of complete rendering and the following message appears: “An error occurred while converting with a codec”.
    This occurs in both Vegas pro 9 and Vegas Pro 10.
    Any way to fix this problem?
    Erik Davis replied 15 years, 4 months ago 2 Members · 1 Reply
  • Erik Davis
    April 17, 2011 at 10:55 am
    Have you installed third party codec packages on your system? I would suggest reinstalling both Vegas 9 and 10 to see if you can solve your coded problem. If reinstalls don’t solve it then you are probably looking at a more serious issue because it would be difficult to find exactly what is the source of your codec conflict. Has it worked in the past for you? Have you changed anything on your system?
    Erik
