Activity › Forums › Square Box CatDV › xdcam proxy size
  • xdcam proxy size
    Posted by Swami Kevala on March 3, 2010 at 12:03 pm
    Hello,
    We are using CatDV to manage a collection of HD video taken with a Sony XDCAM EX3 camera. We have a Matrox compressHD card which we want to use to create H.264 proxies.
    I am running into problems maintaining the correct aspect ratio (16:9).
    On the Preferences/Previews & Thumbnails window I need to specify a size. But it only allows me to specify the width and then automatically sets the height by itself. It will not let me set a size with 16:9 aspect ratio.
    I then select the “Custom” option, where I then have a number of options to specify the size.
    It seems that these two things are conflicting with each other. I cannot seem to produce HD proxy files with the size I want (512×288). Does anyone know how I can do this?
    Kind Regards
    Swami Kevala
    Swami Kevala replied 16 years, 7 months ago 2 Members · 2 Replies
  • Bryson Jones
    March 3, 2010 at 3:52 pm
    If you click the “Customise” button and go into the video settings you can set a size in the QT dialog box, that’s anything you like.
    It should override the first pulldown window in the “P&T” preference pane.
    Try that and see if it works it out.
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
  • Swami Kevala
    March 4, 2010 at 2:09 am
    Thanks – that worked.
    I needed to uncheck the “Preserve aspect ratio using” box.
